HELP!!!
Old Feb 27, 2010 | 08:46 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
HELP!!!
ok i have an 88 iroc. I have installed the 1LE front brake setup but my car is originally a disk/drum car. I want to convert the rear to disk. I'm changing to a fourth gen rear, i will be using that disk setup. Will I HAVE to change out my master cylinder, I know I have to change the proportioning valve or have it re-valved. will this proporting valve work for me? http://www.hawksthirdgenparts.com/82...nlypair-1.aspx It shows only for the 90-92 but i've seen the same part number for 82-92s on other distributors.
Old Feb 28, 2010 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: HELP!!!
No, you have the correct master.
No, that proportioning valve will have the wrong thread pitch for your 88. Here's the one you need:
http://www.flynbye.com/catalog/i40.html
More info toward the bottom in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
