Hurst line lock pics?
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
I'm installing a Hurst line lock and I would like to know if anyone has pics of a Hurst line lock on there 3rd gen they could share, so I could see the correct configuration of the lines as well as were they mounted it?
Thanks!
Thanks!
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
Re: Hurst line lock pics?
i have a B&M if that will do?
ill get the pics
ill get the pics
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Rear exit off of master to "in" on noid. "out" on noid to rear prop valve fitting/threads. simple
Car: 1988 IROC-Z28
Thanks for the reply's,
but there are 6 threaded holes on the unit, 1 each of the top and bottom. 4 around the main bod. Pics would be great, plus good mounting locations too.
I have a summit line locks on both of my cars one is a 2 port and the other is 4 port. The 4 port one is made just like the hurst brand with 1 inlet and 3 oulets. you want to use the single inlet on the main body for the inlet and one of the three for the outlet block the other 2 off. The top and bottom are only used to hold the unit together
Car: 1988 IROC-Z28
Thanks PROFOOTBRAKE2 that's the kind of stuff I was looking for.
Dialed_In
Aug 20, 2015 01:45 PM
