combination valve
Old Mar 25, 2010 | 10:56 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
combination valve
I see that there is two designs for a combination valve on our cars. I have an 85 firebird that I am putting a 96 disc rearend in. From reading on the other post I think I need the 82-early 89 valve with 4 wheel disc or do I need an 1le valve. If I need the 1le valve doesn't it have the M1.5 thread instead of the M1.0. I see where there selling them new for 110.00 but would like to see if I can get a used one for alittle cheaper, so if someone has shoot me a price. Thanks.
Old Mar 25, 2010 | 11:07 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Re: combination valve
I think I found my answer I need the J65 valve. If anyone has one for sale let me know.
Old Mar 26, 2010 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
All 82-92 rear disc cars are J65, regardless of whether the car is equipped with 10.5" rotors and Delco-Moraine calipers or 11.7" rotors and PBR's. For your 85, you need the first-design 1LE valve.
An advert in the classifieds might find you what you need used.
JamesC
Old Mar 28, 2010 | 01:57 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Check this website out...www.inlinetube.com This may help with the line connections ect.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
drptop70ss
Oct 4, 2015 09:44 PM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
