Brake light on
Old Apr 15, 2010 | 03:01 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
Brake light on
Took my rear out to do some work and when I put it back in the brake light is on and wasn't before. I have no leaks and bled the brakes. Will the parking brake being out of adjustment cause this?
Old Apr 15, 2010 | 03:05 PM
Stephen's Avatar
Car: 87 GTA
Re: Brake light on
Very could. Only time mine comes on, is when I pull the e-brake handle so I would suspect that is just the cause of the light being on. Sure the handle is ALL the way down? My light turns on, at only 1 click up..
Old Apr 15, 2010 | 03:15 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Brake light on
Mine turned on RIGHT before the first click. Check it.
Old Apr 15, 2010 | 04:46 PM
mikeirocz1's Avatar
Re: Brake light on
Yeah it's all the way down. I used some pliers to grab the cable and hook it back on the lever on the brakes. I might have pulled it out too far. Not sure if that's posible.
Old Apr 17, 2010 | 12:24 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Re: Brake light on
If you pushed down on the brake pedal while there were no brakes hooked up to the rear, then a little switch on your master cylinder will have to be reset to get rid of the brake light. I'm working on my rear brakes too...
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
