Disconecting the Pressure Differential Switch
Old May 16, 2010 | 11:57 AM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I am converting my car over to manual brakes (not enough vacuum anymore). I got everything plumed and my pressure differential switch or combination valve is obviously no longer used. So my question is my brake light going to be on if I just leave the pressure switch connector hanging unhooked? I Am not up on this switch but I am thinking it is a simple one wire contact (ground) switch, so will leaving it hang open produce no light? Or does it need grounded for no light?
Old May 16, 2010 | 12:10 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: Disconecting the Pressure Differential Switch
the light will be off with the wire disconnected.
you may have to have it hooked up if the saftey inspection station REALLY wants to break your *****.
Old May 16, 2010 | 03:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
just take it off, if the switch need a ground to keep the light off, ground the wire to the chassis, if it doesnt need a ground, cap it off
Old May 16, 2010 | 04:29 PM
weaz4200's Avatar
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
You consider using an Electric Vacuum Pump since you have no engine vacuum? Kinda like this....
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
