89 pbr brakes on a 10 bolt rear
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
does any know if this mounting braket will bolt the 89-later pbr caliper to the 10 bolt rear end?
http://www.hawksthirdgenparts.com/90...rordriver.aspx
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: 89 pbr brakes on a 10 bolt rear
The only difference I can see between that & the original PBR bracket,
is that the originals have a rolled edge, which makes EACH bracket
side specific. Bolt patterns look the same.
What does Hawks have to say?
Good luck,
kk
Good luck,
kk
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
