brake question vacuum or not
Car: 84 Z28 camaro
Engine: 383 stroker
Transmission: turbo 350
my 84 camaro has about 513 hp out of a 383. when i get on the brakes the car will pull to the left, i let off brakes a little & get back on them there fine. they are stock brake size, i was thinking about getting a vacuum canister & upgrading to the ssbc quick change kit with dual pistons. thanks any help appreciated.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake question vacuum or not
Often a symptom of bad brakes lines (they collapse internally and act as a check valve). If the lines on your 84 have never been changed, they're 20+ years old.
If you're searching for brakes, you might consider the selection in the following link:
http://www.flynbye.com/
JamesC
JamesC
Car: 84 Z28 camaro
Engine: 383 stroker
so change the entire brake line system or the one's going to the calipers?
1992 Trans Am
May 10, 2023 07:19 PM
