C6 fronts, LS1 rear disks, LOTS of pedal travel! Help.
Old Jun 21, 2010 | 11:27 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
So I finally got to converting my brakes system. The car is a 1992 RS Camaro which had drums in the rear. I did the LS1 rear swap, front GTO/C6 calipers w/ C5 rotors and braided steel flex lines on all four corners. The axle drop line is still rubber, but it's fairly new.
Problems: I get tons of pedal travel, almost bottoming out the pedal, before the fronts and what seems like only the fronts get pressure. The rears don't seem to be getting pressure. I bled the brakes a few times, but could there still be air in the system? Should I flush the fluid? I know I need a prop valve, although, I read through searching that I can use the stock valve, but that doesn't seem to be working. Is my current/stock MC compatible with my new settup? Thanks, guys!
Old Jun 21, 2010 | 03:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: C6 fronts, LS1 rear disks, LOTS of pedal travel! Help.
sounds like air. how are you bleeding the system? did you let the system drain while working? if so the master has air in it and needs to be bench bled
Old Jun 21, 2010 | 04:49 PM
Ahh ok. I thought I would have to since the lines were left open for a few days. By open I mean the car was on jacks and the rear was out while i worked on it and left the lines unconnected. My dad and I bled them using the pump a few times, hold, release the pressure deal. Would bench bleeding still be needed even if the MC still had a lot of fluid in it even after the lines were left open? Thanks!
Old Jun 21, 2010 | 04:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
no, so long as the fluid didnt all run out of the reservous, you are fine there. Use a suction bleeder, it works much better than pumping the pedal. they are pretty cheap too.
Old Jun 21, 2010 | 05:25 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I _really_ badly want one of these:
http://www.brakebleeder.com/index.ph...=index&cPath=2
Old Jun 21, 2010 | 05:49 PM
That sounds like a plan. I didn't even think about that, nor did my pops who used to be a brake specialist. Thanks again!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
