Help Please
Car: 92 Camaro Z28
Engine: ZZ4 TPI
Help Please
My brakes don’t seem to work all that great to me. Here’s what I have a 92 Z28 disc and drum car that has been changed to the 88 cast iron rear disc brakes. A 92 rear disc combo. valve I don’t think it’s a 1le. I have fixed the calipers with the GM replacement pistons. Cross drilled rotors with performance faction brake pads. and a line lock between the master cylinder and combo. valve. The car seems to have a hard pedal but takes to long to stop on the first stop. After repeated hard stops the front brakes start working great and will lock up under the hard braking. I would like to get the most of what I have on the car all ready.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Help Please
I've read that performance pads often require heating before they function at their best.
JamesC
