no rear brakes with all new parts
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
Hi.
I was having problems with not having rear brakes and weak fronts so i replaced my master cylinder all calipers and put a portioning valve in the line that goes to the rear as the tech article said. and took the stock one out. i have the potion valve open all the way and i still have no rear brakes. would any one be able to guess why I'm not getting any pressure back there. I have bleed them 3 times now and still noting its the same way it was before all the work. I blew through all the lines with cleaner and compressed air to make sure there was no restrictions and replaced all rubber lines.
I'm stumped!
I'm stumped!
Car: 84
Re: no rear brakes with all new parts
the front ones are better when the vacuum is up but the rears still have nothing.
Car: 84
My valve is installed exactly as this one. I have a jeg's valve I set it for the least and I blew threw it to make sure there were no restrictions before i installed it. it sees that the rear calipers want to clamp but they just don't then i let off the pedal the plungers go back into the calipers. I'm confused Member
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
rear calipers siezed? maybe a bad booster. if you didnt bench bleed the master, you probably still have a lot of air in there too.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
