brake noise
Old Jun 26, 2010 | 05:58 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
brake noise
OK. I have searched. The one possible solution is new brake line hoses or new brake caliper bolts. When I drive my car, when I first hit my brakes the car pulls to the right. When I come home to the garage the right front tire skids. After I shut the car down, I hear a bumping, grinding, bump,bump,grind, sound coming from the right (passenger side) of the car. Today I smelled an asbestos hot mell as I was driving in town. What's up? Thank you, Randy
Old Jun 27, 2010 | 05:42 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: brake noise
Try replacing the brake hose. They detioriate and swell up inside and creat a one way check valve situation. And it's possible that the caliper is sticking, but not likely. Also try cleaning and lubing the caliper slid pins with brake grease.
Old Jun 29, 2010 | 05:38 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Re: brake noise
Thank you for the reply! Sorry for the late responce. Just took another trip and still the same problem. I will change the hoses this weekend. I really appreciate your input! Randy
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Randomtask2
Sep 7, 2015 05:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
