rear disc swap!!??
Old Jul 7, 2010 | 01:37 PM
dvdlovesbball's Avatar
Car: 1987 iroc-z
Engine: 5.0 305 carb
Axle/Gears: stock 10 bolt
rear disc swap!!??
i have an 87 iroc with rear drums. i was digging through the junkyard and found a 85 firebird with rear disc brakes. do you know if i could take the whole rear end off and it be compatable with my car?
Old Jul 7, 2010 | 02:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear disc swap!!??
Yes. Get the combination valve (Don't bother if it's iron type as it won't fit your 87), parking brakes cables, and speedo gears (if the ratio is different from the ones in your car) if possible.
JamesC
Old Jul 8, 2010 | 09:53 AM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Just did it myself, direct bolt in (I went from a 10-bolt to a Borg Warner 9-bolt). Make sure you grab the disk brake lines on the axle as well, the drum brake lines are not the same.
-Levi
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
