What size lines...?
Old Jul 8, 2010 | 05:41 PM
j dezzy's Avatar
Car: 87 TA
What size lines...?
I've got the engine out of my TA to swap in a 400. While it's out I wanna change the brake and fuel lines. I know there are a few different sizes of brake lines at different parts of the car. My question is this...Can I just use the same size line everywhere? I was thinking about just getting some 6mm spools and using that across the whole car. If this is not the way to go does anyone know what sizes to use and where? Thanks guys.
Old Jul 8, 2010 | 06:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What size lines...?
the line that goes from the prop-valve to the rear flex line is 6mm. All the other lines are 4.5mm. they have bubble flared ends. So be sure to use the right tool. Or you can get direct fit replacement stainless or regular steel lines from finelines, classictube, classic industries ect.
Old Jul 9, 2010 | 01:45 PM
j dezzy's Avatar
Car: 87 TA
Awesome, sounds good. Is every flare in the system a bubble flare? I noticed my 87 Camaro had some double flares on it. Prolly just the previous owners mistake.
Old Jul 10, 2010 | 10:05 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
all bubble flares in the brake system.
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
