ATTENTION ED MILLER!
Old Jun 3, 2010 | 12:36 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Hey Ed, I purchased your C4 12" setup some years back. When this pad/rotor combo is worn I would like to swap to the 13", HD rotor. Is it as simple as swapping the caliper mounting brackets from the C4 kit to the C4 HD kit? Can I use the same spindles and hub setup that came with the C4 kit? Thanks much
Will
Old Jun 14, 2010 | 10:13 PM
norcalz28's Avatar
Re: ATTENTION ED MILLER!
Anyone?
Old Jun 21, 2010 | 11:51 PM
norcalz28's Avatar
back ttt for curiousity
Old Jun 22, 2010 | 03:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
since all the brake upgrades use the stock cutdown rotor/hub, i would believe that it would just be a matter of swapping the caliper bracket. Unless the calipers themselves are different for the HD setup?
Old Jun 23, 2010 | 08:54 AM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Hey NorcalZ28. I have the same setup as you and after I get bigger rims I'd like to upgrade too. From what I remember, the 1LE hub is used to space the rotor correctly (and its heavier duty). It might be possible to use a wheel spacer behind it, but I don't know if thats a bad idea or not.
Old Jun 23, 2010 | 10:01 PM
norcalz28's Avatar
Seems like it would make sense to be able to just swap brackets, but I figured I would ask the man and see what he said directly. The calipers are the same, so if it's as simple as a bracket/disc swap, I'm all over it.
Will
Old Jun 24, 2010 | 10:50 AM
trumps2000's Avatar
Car: 1985 Z28
I know the bracket is the same for both setups, but the calipers aren't. The C4 standard is a ~0.8" rotor, but the HD is a 1" rotor, so the calipers aren't wide enough to accept the thicker rotor. I know I wish they were.
Old Jun 24, 2010 | 07:01 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
why not just go to hi site and contact him there and see what he says and let us know
Old Jun 24, 2010 | 07:04 PM
Twin_Turbo's Avatar
the bracket for the 12 and 13" setup is the same, the difference is in the bolt hole location on the caliper abutment bracket, not in the spindle brackets. Same bracket for both apps. All you need is the 13" rotor and the proper caliper abutment bracket.
Old Jun 24, 2010 | 10:31 PM
norcalz28's Avatar
I tried contacting him directly, no dice.
Does anyone know if there is a 13" rotor with a .80" thickness? Seems like that would allow me to keep the same calipers and only change the "abutment bracket."
Will
Old Jun 25, 2010 | 04:21 AM
Twin_Turbo's Avatar
I don't think there are any so you will have to change the caliper also. The 12" vette \rotor is only .079" thick, the 13" HD one is 1.1" thick.
84-87
Diameter: 11 1/2"
rotor thickness: 3/4"
inside diameter of the hole on the wheel side: 2 3/4"
inside diameter of the hole on the hub side: 3 3/16"
from wheel surface to outer rotor surface: 1 3/4"
from hub surface to inner rotor surface: 2 1/4"
J55
Diameter: 13"
rotor thickness: 1 3/64"
inside diameter of the hole on the hub side: 3 5/16"
from wheel surface to outer rotor surface: 1 1/8"
from hub surface to inner rotor surface: 1 15/16"
Old Jul 10, 2010 | 09:29 PM
galletti's Avatar
Car: 1988 IROC Convertible
I'm beginning to worry about Ed Miller's health. He was always so quick to answer and help on the boards. I also contacted him through his site, PM and posting and have gotten no answer. Hope he's OK.
Old Jul 10, 2010 | 10:01 PM
spade's Avatar
As a previews custoormer of his I sent an email last week and got a reply on tuesday...... I replied back and still waiting.... He's just busy man...... Took 3 months for my ls1/c5 kit and that was almost 2 years ago.....
Old Jul 10, 2010 | 10:06 PM
galletti's Avatar
That's good to hear. He's got great products!!!
deracer
Apr 11, 2016 12:04 AM
drumstixer
Sep 29, 2015 03:02 PM
gta90
Sep 15, 2015 04:00 PM
Todd84Z
Sep 4, 2015 08:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
