need a little advice
Old Jul 17, 2010 | 12:08 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
I have to replace the powerbooster and mastercylinder on my 86 and was thinking of just going to a manual setup. later on I plan to upgrade the rear to disk brakes would a 1.125 bore mastercylinder be too much? I want to make sure I maintain good stoping power without haveing to yank on the steering wheel to stop after a run down the strip any suggestions?
Old Jul 17, 2010 | 03:10 PM
87350IROC's Avatar
Car: 87' IROC
Re: need a little advice
Is this a street car?
Old Jul 19, 2010 | 08:54 AM
HF_monster's Avatar
Transmission: th350
sorry forgot to mention that yes the car is driven on the street more than the strip. I just dont want it to end up like my old nova where you had to yank on the steering wheel to get it to stop it wouldnt even lock up the breaks.
Old Jul 19, 2010 | 10:57 AM
87350IROC's Avatar
Car: 87' IROC
If you don't want super high effort, why do you want to go to manual brakes? I would stick with power brakes in your application.
Old Jul 19, 2010 | 11:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For manual brakes you need a smaller bore M/C. One with a 7/8" bore is a good choice. Will also need to drill a new pivot point in the brake pedal to move the rod up. This is to provide the correct rod to M/C angle and to provide more leverage.
RBob.
Old Jul 19, 2010 | 06:21 PM
HF_monster's Avatar
Transmission: th350
thank you RBob I should have also mentioned that the cam in the new motor will not support power brakes without a vacuum canister. also makes it less of a pain to change the #5 & 7 sparkplugs or tighten the headers
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
