95 Z-28 brakes on 91 Trans Am, Got a ?
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
As you guys may or may not know I am installing the whole drivetrain out of my 95 Z-28 camaro into my 1991 WS6 Trans Am. I'm using the LT1 rear differential with the 4th gen brakes on the back. However I'm wanting to pull the rotors and calipers off the front and use them as well. What do I need to install the LT1 brakes on my car? I've heard I need brackets and to modify my spindle so is there a write up on this somewhere and a place I can buy the parts needed to use the LT1 front brakes? I'm using the 4th gen booster and reservoir as well, guessing I still need a prop valve? Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
