C4 HD swap with LS1 Calipers?
Old Jul 21, 2010 | 12:11 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
I'm debating doing a front end brake upgrade. Can get most of the hard parts though work at a discount and the rest through Ed. Having trouble getting a rebuilt C4 caliper so.
Are the LS1 calipers compatible with the C4 HD swap?
I know the pads are different, the rotor width between the two is .1", and I can't see a difference in the bracket.
Also is a prop valve swap necissary on this swap? I'm running one for a single piston front/rear disk combo. Would I need to swap to a 1LE or LSX prop valve?
sailtexas186548
Jan 19, 2016 12:21 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
