automatic adjustor
Old Aug 12, 2010 | 06:48 PM
cjh1505's Avatar
Car: 1986 iroc z28
Engine: 5.0 f.i.
automatic adjustor
ok this maybe a dumb question but i figure i will ask. i am doing work on my 86 iroc with disc fronts and drum rear brakes. i have the chevy service manual(thanks ebay) which list one cause of a long brake pedal as being a "faulty automatic adjustors". i look in the manual on how to check and also fix this problem,but nothing that i see. are they talking about the same manual adjustor in the rear drum? thanks in advance!!!!!
Old Aug 12, 2010 | 10:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: automatic adjustor
The little toothed wheel on the shaft that you turn to take up slack when you put new shoes on is actually part of the self-adjusting mechanism.
Old Aug 14, 2010 | 04:24 PM
cjh1505's Avatar
Car: 1986 iroc z28
Engine: 5.0 f.i.
thanks bro!! i re-adjusted the rear shoes and bingo my soft pedal problem went away! thank god for thirdgen.org!
Old Oct 28, 2010 | 01:44 AM
chevysurfer's Avatar
Car: 91 CAMARO RS
Engine: 305 TBI
Transmission: AUTOMATIC
How do you remove the e-brake cable from the lever in side the car. I have the entire center console out and lever and ratcheting mech. unbolted I can swivel it around to get alot of slack on the cable but theres a little tab holding the cord down at the end, and at the end of the cord (it looks like a bicycle brake cable) with a cylinder in a metal cut out but its pushed against another medal plate no way to wiggle it out. IDk what to do pry the metal plate away?
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
