Locked Up Font Passenger Side Brake Caliper
Old Oct 28, 2010 | 09:36 PM
firebirdgangsta's Avatar
I just recently fixed my tranny so that it actually shifts into gear, so I was just working it in my driveway (it's not on the road yet), everything was working fine until the front passenger side brake caliper suddenly locked up. Now it's stuck. Any suggestions as to how to release it so I can get it back up the driveway? (it's down near the end and sorta blocking off my family's other cars)
Old Oct 28, 2010 | 11:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Locked Up Font Passenger Side Brake Caliper
if it's just to move it, I'd disconnect (or just loosen enough to relive pressure) the soft line from the hard line which could be done w/o taking the wheel off. If that didn't do it, popping the wheel off and trying to physically push the caliper piston back in (screwdriver, small pry bar, etc) to release the pads from the rotor would be my two thoughts to just be able to move it a short distance.
Old Oct 29, 2010 | 05:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
more likely than not the internals on your brake hose have failed . they can/will collapse causing a check valve . its a VERY common problem . replace the brake flex line and you should be o.k. . it happened to me but i changed calipers also . a good time to change both rt. & lt. hoses . it is a common problem with older vechicles . it also happened to my old 89 dodge P/U . BTW the ones on our cars are keyed lt. & rt. to the brackets where the hard lines attach . change lines and bleed you will be good to go . good luck .
Old Oct 31, 2010 | 02:35 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Replace the lines - Its so cheap to do.
I've run into a similar problem to this w/ 2 of my previous thirdgens. Brake hoses always fix the issues I've had.
Old Oct 31, 2010 | 02:41 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
x2 on the lines....
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
