bumping into staging beams
Old Aug 16, 2010 | 01:29 PM
GRANDPAW's Avatar
i have a 85 camaro z28 an after the burnout as i roll into the beams,i put on the first light an then pump the brakes an start stalling an let off the brake pedal slowly an the car won't creep forward like my 55 does,it suddenly rolls all at once after the pedal is raised about a 1/2'".it has new calipers and front hoses with power brakes an a crane vacuum booster can.just wondering if anyone else has had this problem?just seems like the calipers don't release slow,just all at once.
Old Aug 16, 2010 | 07:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: bumping into staging beams
Don't try to force yourself into the beams. Stop when you turn on the prestage beam then gently release the brake and roll into the stage beam. Stop as soon as the stage light comes on unless you want to try deep staging. I doubt you're using a pro tree and launching off really high rpm. You have plenty of time to come up on the converter after the stage light comes on. You don't need to do it at the prestage bulb.
Old Aug 17, 2010 | 07:05 AM
GRANDPAW's Avatar
so you are saying don't stall up till the 2nd stage bulb is lit.i will try that at test an tune to get used to it because i would hate to be watching the tach to 2000 an all of a sudden the tree starts counting down .i like you idea,it makes sense,thanks a lot for your help.
Old Aug 19, 2010 | 05:39 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
Have you tried staging the car at a lower RPM and bump in like you talked about
Old Aug 20, 2010 | 07:47 AM
GRANDPAW's Avatar
haven't been back to the track yet.it just seems like the car won't ease in to the lights,like the brakes won't let go slow,kinda all at once.hard to describe,my son thought it was me till he deepstaged trying to ease in also.its not pushing through the brakes like trying to stall to much,it just finally moves after the brake pedal has moved up a whole lot.it just started this but we'll keep practicing or maybe we'll install a new master cylinder or maybe put on manual brakes if i can find a way to run without a booster.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
