Shim/ no shim Rear LS1 brake retrofit
Old Aug 24, 2010 | 05:15 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
For some reason, I haven't found the decisive answer. When adding ls1 brakes on a drum rear axle, do I need to shim the backing plate?
Old Aug 24, 2010 | 05:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Shim/ no shim Rear LS1 brake retrofit
i didnt have to. I believe the shim is for the lt1 (93-97) style brakes
Old Aug 24, 2010 | 05:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
89-92 10-bolts cars with PBR's had shims if needed--I've read that the 89 9-bolt didn't require them.
JamesC
Old Aug 24, 2010 | 09:29 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
i had to on the drivers side but not pass side, youll know when you get them on
Old Aug 25, 2010 | 11:10 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
I did not need to.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
