Baer Rotors or System Replacement?
Old Aug 30, 2010 | 12:40 PM
SweetRide45's Avatar
I have a question about what size/type rotors I can go with. I currently have Baer Brake Sport/Touring kits on my '90 Firebird. I want to get replacement rotors, however, I'm not seeing any 12" that duplicates what Baer uses. Here are the kits:
Baer Claw Systems, Front 84-92 F-body. (Sport) PBR 2 Piston, 12" x 1.10" Rotors
Baer Claw Systems, Rear 89-92 F-body, OEM 9 bolt with disk. (Touring) PBR Single Caliper, 12.00" x .81" Rotors
I'm thinking I could go with '95 Vette ZR1 fronts/rear...but I'm not sure of the thickness of those rotors. Also, would 13" fit? I haven't looked that close at my setup to see if they'd clear or not.
I'm seeing DBA makes Baer rotors and I might be SOL...however, 93-97 FBody rotors may fit the rear.
If I'm going to be spending $700 or so for freakin' BAER rotors, I'll just junk this setup and go w/ EbMiller.
Thanks!
Old Sep 6, 2010 | 09:38 PM
Re: Baer Rotors or System Replacement?
I think I'm just gonna get stock replacement vette rotors, screw the drilled/slotted bs
Old Sep 7, 2010 | 07:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
arent they just c4 HD rotors?
if you can return them, maybe try a set and take some measurements amd see if they are the same
Old Sep 7, 2010 | 07:17 PM
They aren't the HD's, b/c those are 13". Yeah, that's what I plan to do, just get one and test fit them. I read that the "rear" vette rotors are different offset, so it'd have to be front vette rotors all around...Idk the truth to it, but we'll see.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
