Bleeding with vacuum pump
Car: 88 Camaro V6
Hi,
If I use a vacuum pump at the bleeding valves on the calipers, is it still necessary to bleed the master cilinder first? Or will all be bled in one effort?
Thanks for your reply.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Bleeding with vacuum pump
You'll still need to bleed the cylinder if it has air init.
theshackle
Mar 5, 2017 06:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
