best brake upgrade under $1000
Old Sep 2, 2010 | 06:46 PM
lkefthrlkeson's Avatar
Hey guys, trying to plan out my brake buildup. I've budgeted $1000 for everything. Just wondering what kind of budget brake conversion are out there. I know people have switched to ls1 brakes etc... I want something that is easy to install and will provide the best braking possible. Don't know if it matters, but I'm gonna be running 18" wheels. Thanks for the help.
Old Sep 2, 2010 | 07:42 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: best brake upgrade under $1000
Are you looking for front brakes, rear brakes, or both? I have a 4 piston wilwood setup in the back. I have no complaints about it, other than they just touch 15" draglites. But if your running 18's, then that wont matter. I like that the parking brake is an internal drum so the caliper looks cleaner. I have an adjustable proportioning valve on the rear and I have to turn the pressure way down or they easily overpower my front brakes.
Old Sep 2, 2010 | 08:31 PM
looking for both front and back for under 1000. Just trying to get an idea of what budget brake upgrades are out there.
Old Sep 3, 2010 | 07:59 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I'm going to say LS1 brakes then are an excellent upgrade.
I just picked up the rotors, calipers, pads, and lines for $125 shipped for the fronts. I need to turn down a stock rotor, modify the spindle, and buy the abutment brackets from Ed. I already replaced my 9bolt with one out of a 02 LS1 3.23s.
Old Sep 3, 2010 | 08:34 AM
built91Z28's Avatar
Not to hijack, but will the LS1 front brakes fit under 15" rims?
Old Sep 3, 2010 | 09:17 AM
I haven't done it yet, and it was never a consideration so I don't know for sure. But my guess is no. I'd search the boards, the answer will be there.
Old Sep 14, 2010 | 01:47 AM
87350IROC's Avatar
Car: 87' IROC
Why are you interested in rears too? Spending $1000 on front brakes will get you a lot further than spending $1000 on front and rears.
Old Sep 14, 2010 | 02:31 AM
3genpio's Avatar
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
I have a 14'' with cts-v brembo calipers
calipers, loaded, shipped -400 usd -ebay
rotors -68 per piece+ shipping from GMPD
brackets you can get under 100 i gues,
spindles and hubs- you can modify by yourself if not i belive less than 200 inc spindles
new brake lines?- no idea i have used my old C4 lines
if you know a metal shop you can do all kit for less than 900 usd
brgds
Old Sep 17, 2010 | 01:24 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
So you're actually suggesting to have disproportioned brakes?
I would never suggest upgrading the front and not the back brakes.
Old Sep 17, 2010 | 02:26 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
The answer to that is no, I'm afraid. They require a 16" rim
You can fit C4 brakes (Not the HD version) under 15" rims though
Old Sep 17, 2010 | 02:54 PM
87350IROC's Avatar
Car: 87' IROC
Its only disproportioned if you don't do something about it. Have you ever driven an '84-'88 4 wheel disc car? They are incredibly disproportioned from the factory. I run an adjustable valve to set the bias.
I have raced on open road courses with upgraded front brakes and stock rear '87 discs. The rear discs work great lap after lap. Even turn 2 at Evergreen slowing down from 135-60 in a 3500lb car lap after lap. I don't see any reason to upgrade rear brakes except for looks.
I'm curious to hear your reasons for suggesting a rear upgrade.
Last edited by 87350IROC; Sep 17, 2010 at 02:55 PM. Reason: added smilies to mimick BlueZee
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
angel2794
Sep 8, 2015 06:22 PM
Night rider327
Sep 2, 2015 04:17 AM
zayne0
Aug 24, 2015 07:22 PM
