01 LS1 brakes on 90 IROC banjo bolt hitting lca
Old Sep 9, 2010 | 07:56 PM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
I've just finished installing 2001 z28 front brakes on my 1990 IROC, along with SPOHN LCA, and the banjo bolts hit the LCA before my steering locks out. I have the bleeder screw on top, would it matter if it was down? I can switch the calipers and gain a little more turn radius. Then with full lock I hit the caliper body. Any feedback would be very helpfull.
Thanks in advance,
Tim
Old Sep 9, 2010 | 08:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 01 LS1 brakes on 90 IROC banjo bolt hitting lca
you cant flip the calipers, the bleeders have to be on top.
so th brake hose hits the steering stop? trim the stop so it clears. Had to do that with my 1le setup
Old Sep 9, 2010 | 08:22 PM
myzblubyu's Avatar
There is no steering stop since I'm using the SPOHN LCAs. If I can't flip the calipers I'll just have to deal with it. This may only be a problem trying to cut it sharp for a parking spot or a u-turn. I'll post a picture of the set-up tomorrow.
Old Sep 9, 2010 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well, since you have the after market arms, without stops, the wheels will turn further than they would before, same with my UMI arms. Spohn has a steering stop for their arms, pretty much just a shaft collar. I would do something if the brake line is hitting anything, dont want to break it off by accident and cause an accident.
strange though, but i dont have this problem with my c5 setup on my 86. Do you have the lines attached ot the banjo bolt backwards?
Old Sep 10, 2010 | 01:38 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
my calipers hit my steering stops too. can get 90% turn radius from it tho. i dont mind giving up some turn radius to feel more confident that i can stop.
Old Sep 10, 2010 | 06:43 AM
myzblubyu's Avatar
I have the lines on correct, only one way to go on. I'm using 1LE brake lines. I'll order SPOHNS bump stops today.
Old Sep 10, 2010 | 06:58 AM
myzblubyu's Avatar
That is the way I feel too. The factory front brakes were barely adequate to say the least. Now I have 12 inch brakes all the way around. I'll get it off the stands today and drive it to get the alignment done. I replaced everything up front, from the K-member to include all front and rear suspension. I'll order steering stops from SPOHN or make my own. I just didn't know If I could flip the calipers and put the bleeder on the bottom.
Thanks,
Tim
Old Sep 10, 2010 | 06:59 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
watch out if that bango hits enough times on that arm it could come loose my buddy had that problem iuntil he made some stops up for his setup i just moved my factory stops in farther and made new holes on the factory arms and i see you have the aftermarket ones
Old Sep 10, 2010 | 08:13 AM
myzblubyu's Avatar
I'm still trying to post my pictures... I loaded the pictures in an album in my profile.
https://www.thirdgen.org/forums/albu...ictureid=16877
https://www.thirdgen.org/forums/members/myzblubyu-albums.html
Old Sep 17, 2010 | 10:17 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I've got C5 fronts with stock a arms and had the same problem. I just took a BMFH and bent the stops out a bit which fixed it right up.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
