Part number confusion
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I'm trying to figure out what I already have available to use out in my garage. I have an assortment of master cylinders and prop valves that I kind of remember where they came from. Then I decided to look up the numbers and label them, but now I'm even more confused.
I have three different master cylinders, two with a small bore, and one with a large bore... but they all have the same part number. What gives?
Do the prop valves not have the actual part # stamped onto them? The stamped # doesn't seem to be a GM part number. The ones I have are either "NB" or "NC" code. One is supposed to be disc/disc, the other disc/drum, but that doesn't jive with what they were removed from.
Engine: that I like
Re: Part number confusion
bump. The prop valve numbers are what concern me the most.
The numbers on the combination valve appear to be useless where ID is concerned.
JamesC
1992 Trans Am
05-10-2023 07:19 PM
