Thread: 91 Camaro Clutch Master Cylinder/Brake Booster Removal??
Old Sep 12, 2010 | 12:04 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Transmission: Manual (5 speed)
Axle/Gears: Currie 9' (4.11)
I am having a very hard time removing my clutch master cylinder from my car. I have removed the slave, unbolted the two bolts under the dash on the fire wall and removed the reservoire. I can not get the U bolt to pull through the holes in the firewall (think it is rusted). I would like to remove the brake booster to have better access to the clutch master but I have never removed one before can anyone tell me how?
Thanks to all who reply
Old Sep 12, 2010 | 12:37 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: Thread: 91 Camaro Clutch Master Cylinder/Brake Booster Removal??
Hey Dragn, try using a long drift punch to coax the u-bolt out, screw the nut's back on just enough to protect the threads, and just giv-em a good whack with a mallet or hammer. Mine was stuck also, but it will give, without having to remove the brake booster.
Old Sep 12, 2010 | 01:04 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Thanks ill give it another shot I have hit it with a hammer a few times with no luck but I wasnt really pouding on it lol. Thanks for the tips ill put the nut back on and try to break it loose.
Would you know if I can just replace the hose (since its the only problem) or do I have to get a new master and slave?
Old Sep 12, 2010 | 01:20 PM
92 BBC Z's Avatar
Which hose/line? The one to the resevior, or the slave? If its the one for the res. stop NOW. There is no reason to remove the master cyl. If its the slave line, then yes the master cyl. needs to be removed becauce of the small drift pin that needs to be removed and reinstalled.
Old Sep 12, 2010 | 01:43 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Ya sorry it is the hose going from the master to slave did you change yours with the engine pulled? I can barely fit my hand behind the brake booster but ill keep trying thanks again.
Old Sep 12, 2010 | 03:00 PM
92 BBC Z's Avatar
Well, I've done it both way's. Once when the motor was out, I installed the line your changing now, then after the motor was installed I had to replace the whole master cyl. and res. There is one thing I noticed, the u-bolt isn't a perfect "U" shape. It was kind of a "closed" U, which made it "hang up" a little passing through the firewall.
Old Sep 12, 2010 | 03:06 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Ok you have been a great help once my tour is over ill give it another try and post the results. Thanks
Old Sep 12, 2010 | 05:04 PM
92 BBC Z's Avatar
Best of luck. Hope to here from you again.
Old Sep 16, 2010 | 02:40 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Finally its free but it sure was not easy:[ Now I have to wait till my new hose comes in the mail. I got a DEI heat sheath for the new line to keep it from melting again. Thanks for the help is there anything I should know before I install the new line and put everything back together? How do I bleed the slave what should I watch for ect?
Old Sep 16, 2010 | 03:33 PM
92 BBC Z's Avatar
Well I guess I should've mentioned that I believe Mcleod makes that line in a steel braided version, no need for the heat shield. As for bleeding,bench bleed the cylinder first,( submerg the line connected to the cyl into a container of brake fluid and pump until it flows fluid freely, no spitting of air)then install the cylinder,then the line, connect line to the slave, but dont connect to the fork yet, fill the resv with fluid then pump the pedal untill the slave extends and retracts completly and smoothly,this should only take a few pump as there is no return line. Then install the slave. Done.
Old Sep 16, 2010 | 03:50 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Wow you make it sound pretty simple stupid question since I am new to this repair but what is the best way to put the master cylinder back in should I feed it up from the bottom or reach over the fender and try to line it up that way. I might be working on this by myself so any tips help thanks.
Old Sep 16, 2010 | 04:26 PM
92 BBC Z's Avatar
Well, if you do it from the bottom you probaly can't see it, so do it from the top over the fender. If you need to use a piece of safety wire and feed it through the firewall/cyl mount holes just to hold it in place long enough for you to go around and nut it. I kinda figured that as hard as it was to remove, that it would be a little stiff going back in, making it easier to nut.
Old Sep 16, 2010 | 07:51 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Cool that's what I was hoping for ill keep you posted.
Old Oct 2, 2010 | 11:20 PM
xtx's Avatar
xtx
My wife says inside under the dash, if you took off those nuts, there is still a bracket over it. Pull or bend this bracket away from the bolts, you can bend it back later. Now look under the pading. You will find "HIDDEN" a flat sheet metal lock washer keeping you from pulling the unit through the fire wall. Next crawl under the car and remove two 11mm screws holding on a heat shield on the drivers side under floor. under this you will see a braded hose line that runs to your Master cylinder and then over to the trainy slave cylinder. You need to use a tool that only costs a few dollars that removes fule lines, air condition lines and yes....it also depresses the quick disconect for this braided line on the trainy. It just goes around the fitting and push it into the trainy and out pops your line. You can now go back up top and remove the master cylinder without damaging anything. once you have it out then you can push the roll pin out on the master cylinder to switch the line to the new one. I said my "wife say"s because i was well into a 12 pack and fixing to break out a cutting torch when my wife went outside looked inside and solved the problem. good luck
Old Oct 3, 2010 | 12:29 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
lol thanks for the tips if that was my wife she would just tell me if you can't fix it too bad quit spending money on that stupid car...I did manage to get the hose off and have been waiting for the replacement hose to come for 6wks. I ll let everyone know how it goes once i get it back together.
Old Oct 12, 2010 | 09:42 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
Well I finally got this PIA job done thanks for all the help and advice btw putting that U bolt back on by yourself is impossible get a friend with tiny hands. I took the car out for a test drive no gear grinding everything seemed to be working fine...then the car gods kicked me in the ***** and the plastic clip that holds the rod on the clutch pedal coming from the clutch master broke so I had no clutch and had to limp my car home in first gear. I am going to try and use a few C-clips to hold it on the pedal do you think that will work any suggestions are appreciated.
Old Oct 12, 2010 | 10:16 PM
92 BBC Z's Avatar
Just buy a replacement, no sense in spending anymore time on trying to make something work, plus that part isnt to hard to find. If you have any problems finding it let me know, i'll find one.
Old Oct 13, 2010 | 10:38 PM
Dragn's Avatar
Car: 91 Camaro RS
Engine: 360 SB
K sounds good just wish the factory piece was not plastic...I can only get this part from a GM dealer and they have to order it from the U.S. it costs $17.00 cnd and will take 10 days to come. If you can get me one that would be great but don't go out of your way you have already helped me quite bit. The wreckers here won't sell just the bushing so I can't even scavenge one. Any help appreciated thanks again.
Old Aug 11, 2019 | 05:31 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Use the metal clip from a 4th gen, fits right on.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
rsrmoore
Aug 7, 2015 08:44 PM
