Car pulls left / right after front end rebuild.
Old Sep 16, 2010 | 01:31 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Guys,
I just recently got my car registered again and started to drive it. A few years ago i got in a little accident. Long story short: I replaced everything from the K-member, shocks, lower control arms (stock) LCA bushings, Ball joints and tie rods. Now, I haven't had the car alinged yet. Some times the camber / caster is visably off, other times it looks good. I know i need an alignment and i will do so. Do you guys think that my car being that far out of alignment spec would cause my car to pull side to side while breaking? Before everything the breaks were fine.
Also, how much ball park for an alignment on these cars in a situation like this?
Thanks,
Old Sep 16, 2010 | 02:15 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: Car pulls left / right after front end rebuild.
dude, you just unbolded everything and ask if you need an allignement.
some people even do an allignment when they change the balljoints alone.
Old Sep 16, 2010 | 02:19 PM
Car: 91 Firebird
Engine: Turbo 355
Read above. I state i know i need an alignment and will do so. I was just wondering if this will cause my car to pull to the left and right WHILE BRAKING.
Old Sep 30, 2010 | 07:02 PM
hagerty438's Avatar
Car: 1985 Camaro Z28
Engine: 355
Axle/Gears: 7.5 with 4.11 gears
my car did that too it was because my brake calipers were sticking. i put new pads on the car the other day and where it hadn't been driven for a while and had worn pads when I pushed the piston back in to make room for the new pads the calipers really were sticking then. they were sticking so bad my brakes cought fire!
Old Oct 1, 2010 | 05:39 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You already said that you know you need an alignment. You are asking why you have these symptoms, and you already know why. Get your front end aligned. If you still have issues, then ask for help. BTW, how bad was the damage? You didn't bend the frame did you? You may end up putting the car on a frame rack to have it straightened. After you get the front end ailigned of course.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
mizz0313
Aug 12, 2015 06:45 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
