master cylinder swap
Old Oct 8, 2010 | 09:50 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I've read a lot of threads on this subject and I seem to be confusing myself and just want to make sure.
I have a master cylinder from a LS1 car, and like I said just making sure.
do I need to do anything els to make this work....is this a TRUE plug and play.
I know the threads for the brake lines to the porportioning valve work.
please let me know
thanks
Old Oct 10, 2010 | 08:07 PM
gscz28's Avatar
Car: 89 iroc
Re: master cylinder swap
WOW....thought i would leats get something about searching...but some the threads are confusing......oh well
about this....I have rear drums will this cause a problem with the LS1 M/C???
Old Oct 10, 2010 | 08:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the master will fit, you may have to tweak the brake liens form the master to the prop a little. It won't cause a problem with the rear brakes.
Old Oct 10, 2010 | 08:35 PM
gscz28's Avatar
Car: 89 iroc
sounds great thanks....I even went and sanded and polished it....will post pic in a day or two..
again thanks
Old Oct 10, 2010 | 08:42 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Post your results - I installed my LS1 M/C and now my brakes SUCK - They have been bled, and bled, and bled and still the same, crappy pedal and the car feels like it won't lock up the brakes anymore. Same setup as you, disc/drums.
Post when you install it and let us know what your pedal feels like.
Old Oct 10, 2010 | 08:48 PM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
youguys try changing proporting valves ,put 3rd gen all disc since they hold more pressure
Old Oct 11, 2010 | 07:37 AM
gscz28's Avatar
Car: 89 iroc
will keep that in mind....thanks
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
