rear drums to discs rear end swap confussion
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Ok. So I have found a 9 bolt 3.23 disc break posi rear end on craigslist. It is just the rear-end with the hoses, no lines.
Now originally I thought that the whole master cylinder would need replaced, but after looking at this article:
https://www.thirdgen.org/propvalve
It sounds Like all I have to do is install a prop valve and run the lines and possibly swap E-brake cable
so I am just looking for someone to set me on the correct path so i can get my baby back out on the road!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: rear drums to discs rear end swap confussion
you will need the proper e-brake cables, and a prop valve from a disc/disc car. Or, you can gut your existing propvalve and install a adjustable one for the rear circuit.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Either master cylinder will work, the only difference will be pedal feel and travel. You just have to change the parking brake cables and combo valve.
Car: 1985 trans am
Transmission: 5spd
Ok, So on summit wilwood has 3 different valves, does it matter which one I would use?
http://www.summitracing.com/search/B...rtioning+valve
I think it would be easier to screw with the master cylinder I have and make it work than find one, because the rear I found the guy doesnt have it.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Info here on master, combo valve, and cables may be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
