Rear drum to disk conversion question
Old Nov 2, 2010 | 11:44 AM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Ok, I have gathered all I think I need except e-brake cables. I took a set of rear disk brakes off of a Blazer 4wd (drum ebrake). I got everything except e-brake cables. I saw a LTI camaro and it had brake cable ends that looked the same for what I need. Is this the application I am looking for?
Also, can I put my system together and use my disk/drum master and prop valve until I get my hydro boosted LS1 master and adjust prop valve setup finished? (still collecting a few parts)
EDIT: The car is an 83 Z28. The parking brake cable mounts to the bottom of the backing plate on the blazer brakes but has the same rectangle cable end that the caliper mounted LT1 cars do.
Old Nov 2, 2010 | 03:01 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Rear drum to disk conversion question
For the drum to disk conversion to work correctly you'll have to install a matching disk/disk proportioning valve.
Question is, why put off your plans for the hydo boost and an adjustable proportioning valve?
Old Nov 2, 2010 | 03:19 PM
supr_fly03's Avatar
Car: 83 Z28
I have to get the car rolling to bring it out of the garage and paint the t-top area and door jamb areas I repaired. The hydro boost/LS1 master/LS1 front brake conversion stuff will be done before it hits the road.
I just put a 5spd in it and I need an ebrake so it wont roll around.
Old Nov 2, 2010 | 03:28 PM
Wadebryant's Avatar
Then you really dont need it road worthy yet? Just a working e-brake? For that you dont need a proportioning valve either but if you do and dont want to fork out the cost of a new disk/disk valve, you can go on the cheap and install a used disk/disk valve as they dont ususally wear out. Try the classifieds on this site or a wrecking yard.
Good luck with your project
Old Nov 3, 2010 | 09:56 AM
supr_fly03's Avatar
Car: 83 Z28
Does anyone know if the later PBR style ebrake cable will work, or if LT1 cables will work?
jaridjohn
Jul 8, 2024 03:49 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
redmaroz
Aug 16, 2015 11:40 PM
