rear disc upgrade
Old Nov 23, 2010 | 07:12 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
rear disc upgrade
i just recently put a new rear in my car out of a firebird . was told a 89. it is a 9 bolt with the old iron calibers. when i am on wet grass i can put the car in drive and hold the brake with no throtle the rear tires will spin. i did do the prop valve and i have it wide open and i am getting plenty break fluid at the calibers.is there an easy fix or do i need to replace them.
also i was wondering if i could swap the newer 4th gen ls1 brakes on ther easy
thanks
bruce
Old Nov 24, 2010 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear disc upgrade
thanks
The rear, if an 89 with discs, would have PBR's, not the old style Delco-Moraines. The Delco-Moraines have a reputation for being unreliable if the parking brake isn't used frequently. The following site sells the 'fix it' kit (I'd probably just replace the calipers if indeed they do require the kit):
http://www.flynbye.com/catalog/i208.html
The LS1's are set up for a 10-bolt. I don't know of any kit/equipment that will allow a swap.
JamesC
Old Nov 27, 2010 | 01:39 PM
usacamaro's Avatar
Car: 92 rs & 89rs
i know there might be something on here but i cant find it. is there anything that i can do to upgrade the 9bolt with the Delco-Moraines to anything better
Old Nov 27, 2010 | 02:44 PM
JamesC's Avatar
Sure, the above site sells 9-bolt backing plates and PBR's.
JamesC
Old Nov 28, 2010 | 12:37 AM
usacamaro's Avatar
Car: 92 rs & 89rs
if i was to buy the 9bolt backing plates would the 4th gen ls1 brakes bolt up to them. just trying to get away with this cheap as possible ive seen the prices of new pbr's.
Old Nov 28, 2010 | 06:02 AM
JamesC's Avatar
See post #2. Note that the PBR kit is a bit cheaper than the LS1 kit from Ed's site.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
