Parking brake cables for PBR swap
Old Nov 27, 2010 | 08:15 AM
skinny z's Avatar
As always, I've done my due dilligence and searched.
As usual, there is SO much information (some of it conflicting) that I can't determine the answer.
Question 1: What are the lengths of the parking brake cables on 3rd gens equipped with PBR rear disc brakes? 1434mm or 1460mm?
I recall having read (I may have asked before!)) that if the vehicle is equipped with a trans tunnel mounted adjuster, then the 1434mm cable is the way to go. Sound right?
Question 2: Has anyone had any experience with the PBR swap onto a Dana 44?
I don't imagine there would be any difference in the cable requirements.
Old Nov 28, 2010 | 06:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Parking brake cables for PBR swap
The 1434 is what I used on my 85 (with the tunnel adjuster).
JamesC
Old Nov 28, 2010 | 06:08 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Same here, but I did it on a stock axle.
Old Nov 28, 2010 | 08:03 AM
skinny z's Avatar
JamesC
Sounds like the 1434 is the way to go.
Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
timonator
Aug 13, 2015 11:27 PM
