PBR Chirp
Old Dec 7, 2010 | 10:48 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
PBR Chirp
Please help me before I lose my mind. I run an 89 PBR setup on my 12-bolt. I noticed a "pulsating chirp" on one side. After hours of trying to isolate the noise, I found it coming from the springs/clips at the trailing edge of the pad (not the wear indicator), where it contacts the caliper. I've tried PB Blaster and simple oil, but to no avail. What could I use to stop the chirp?
Thanks for the help,
Eric
Old Dec 8, 2010 | 09:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: PBR Chirp
I use dialectic (silicone) grease on the brake parts. This is on the sliders, pins and so on. Not sure if it will work or not. Is the rotor possibly warped?
RBob.
Old Dec 8, 2010 | 11:34 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
Re: PBR Chirp
I verified w/ a new rotor that it isn't warped. I can make the noise occur by moving the caliper laterally, put my ear right next to the caliper and heard it from the clips. I'll try your suggestion and maybe tighten a few bolts too.
Thank you for the advice.
Old Dec 11, 2010 | 08:57 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
Re: PBR Chirp
After another round with the flashlight and trained ear, I realized I could not actually pinpoint the noise. Spot-lubing didn't prove very helpful either, so I shot the entire assembly aft of the pads with PB Blaster. No more chirp.
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
dbrochard
Sep 25, 2015 04:56 PM
///DAN///
Sep 25, 2015 02:15 PM
Abubaca
Sep 20, 2015 09:35 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
