Brake booster ??
Old Dec 20, 2010 | 06:37 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Brake booster ??
This is a long time issue. Car was put on hold with the birth of my daughter and am now getting back at it. Im 1/3 of the way into a T56 swap and am wanting to tackle this brake issue shortly after. Im at a loss as I cant figure out whats happening. Had lots of great suggestions from board members but cant get it done. Heres a copy from a old old post. Again I appreciate any help/suggestions.
Heres a quick run down of braking issues with my 91 Z28 1LE 355 .
Car has horrible braking. Cannot for the life of me come anywhere close to locking up my brakes even if I two foot her. The pedal isnt spongie or soft. It feels like it used to when I could lock up the brakes. However, the pedal goes hard after 3-4 rapid pumps. It feels like there is no vacuum left in the booster. Has lower vacuum due to the cam. Heres what I have done so far with no real improvement
1) Added EARLS stainless braided flex lines
2) Tried a vacuum resevoir
3) Replaced can with SSBC vacuum pump so no low vacuum issues
4) Flushed and bled and bled and bled fluid
5) Verified visually the calipers are moving and not binding
6) Changed rear calipers , pads and rotors
7) Cahnged brake master cylinder
8) changed booster check valve
9) changed front calipers, pands and rotors
Ive got a new combination valve to go in. Im now ready to just bite the bullet and buy a new brake booster. I am concerned about quality of boosters. Does anyone have any experience or recommendations on boosters? OEM vs. aftermarket? Is it possible to rebuild them?
Thanks in advance.
Kris
Old Dec 27, 2010 | 11:13 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Brake booster ??
I'm going to bump this. I have similar issues with my 87.
Old Dec 27, 2010 | 11:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Describe your vacuum plumbing, and have you vacuum tested the booster?
Old Dec 29, 2010 | 09:03 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
I have only done the "pump the pedal until its hard and then start the car and the pedal sinks" test. Plumbing wise I have tried the hose from intake plenum to booster check valve and now I have it plubed from the electric pump to booster.
Old Dec 30, 2010 | 12:09 AM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I just put a hydroboost on mine from a astro van. Brake pedal feels good, high and a little firm.
Old Dec 30, 2010 | 01:46 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
What year Astro van did that hydroboost come off?
Old Dec 31, 2010 | 02:08 AM
supr_fly03's Avatar
Car: 83 Z28
I dont know the exact year. I know I got one that extends strait out from the firewall, not up at an angle. The newer front clip models with the curved headlights have the kind that come up at an angle, the older square headlight models come strait out and had the required flat bracket.
eustodp
Sep 20, 2015 05:09 PM
dbrochard
Sep 19, 2015 08:13 PM
sylentnite
Sep 9, 2015 02:55 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
