Racecraft Manual Conversion Plumbing?
Car: 86' Iroc-Z
Engine: 355ci
Transmission: Turbo 350
Axle/Gears: 4:56
Im putting a Racecraft manual kit on my 86 iroc, its factory front disc/rear drum. Was wondering if i plumb it with the factory prop valve that was on it, get an aftermarket, or ive seen alot of guys not running a prop valve at all with the Strange master cylinder that comes with the kit.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Racecraft Manual Conversion Plumbing?
you dont need a prop for the front brakes, you can plumb them direct, but you will need a adjustable valve , for the rears to get the bias right.
