LS1 e-brake brackets with LCA relocation brackets
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am going to be installing my LS1 rear brakes and e brake cables today and was wondering how I should go about installing the brake cable brackets since my car has lower control arm relocation brackets on it? Has anybody had this issue before?
Car: 86 Trans Am
Engine: 408 stroker sbc
Re: LS1 e-brake brackets with LCA relocation brackets
you have the cut the inside part of the e-brake bracket off, or cut it in half and weld in a small piece to make it wider. Honestly, you can just cut off the inner ear and be done with it, you could even put a bolt through the back to make it more stable, or tank weld it in place on thge back of the relo bracket if you so desire.
I just have them cut on my 86 and have not issues.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I just grind off the welds, bolt them in place and reweld but you need to shorten one side and redrill the hole.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
