83 rear disk
Old Mar 11, 2011 | 01:50 PM
prostk's Avatar
Car: 83 z28
Transmission: 5 speed
83 rear disk
I'm doing a full brake job and noticed that the passenger rear has a rubber hose going to the caliper and the driver side is a hard line is this factory? I also wanted to upgrade to BSS hoses and seen kits with 3,4 and 5 hoses all for the same car.
Old Mar 11, 2011 | 01:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 83 rear disk
Yes.
Four lines (two to the front calipers, one to the rear center and one to the rear caliper).
JamesC
Old Mar 11, 2011 | 02:48 PM
prostk's Avatar
Car: 83 z28
Re: 83 rear disk
Thanks, but what's up with the kit from Rick's camaro it shows 5 lines do you run a flex over to the drivers rear side also?
Old Mar 11, 2011 | 02:57 PM
JamesC's Avatar
Re: 83 rear disk
No, that line is hard. Sometimes pics aren't really representative of what you're purchasing. An 89-92 car with 4-wheel disc brakes, for example, would have five lines, as both rear calipers are equipped with a soft line.
EDIT: Check this site for a 4-line:
http://www.classictube.com/store/ind...duct_ID=140444
JamesC
Old Mar 26, 2011 | 07:08 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Re: 83 rear disk
i really like to remind people to replace the soft line that sits on the diff and then goes to the rear calipers,,everyone always replaces the two front and rear caliper soft rubber hoses,,but always forget that center hose...in some cases ,,it up to 25+ years old..needs to be replaced .
Old Mar 26, 2011 | 10:41 AM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: 83 rear disk
I picked up a 1984 3.73 disc rear to put on my 86 so I can ditch the drum brake 2.73 gears on it. Figured I would put new pads, calipers, rotors, and lines on. That center hose was very hard and cracked up on the 84 axle. Got all my lines at NAPA, was pretty cheap.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
