e brake cables need info
Old Mar 14, 2011 | 06:16 AM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
im swaping my drum rear end out of my 92 rs for a 88 rear end disc out of a iroc the e brakes were shot when i removed them where can i geta new set of cables? also are all e brake cables that have rear disc brakes the same for all the years of the camaro if not what year should i get a 88 cable 92 cables that were for disc brakes ?
Old Mar 14, 2011 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: e brake cables need info
82-88 cables, which accompanied the old-style iron Delco-Moraine calipers, and cables for 89+ with PBR's are different.
Your 92 should have a self-adjusting parking brake, but to cover your bases take a look. If it should have the adjuster seen below (or you swap one in), use cables for an 88. The 89+ cables won't work.
https://www.thirdgen.org/forums/atta...e-adjuster.jpg
JamesC
Old Mar 14, 2011 | 08:46 AM
Transmission: auto
so tour saying if i have the e brake adjuster i can jus use my 92 e brake and if i dont buy the adjuster and the 88 cables
Old Mar 14, 2011 | 09:00 AM
JamesC's Avatar
If you have the adjuster (which I doubt you do), use cables for an 88. The cables made for your 92 will not fit the old style Delco-Moraine calipers on the 88.
The adjuster is spot welded in place, IIRC.
EDIT: It seems to be that if your car requires the tunnel adjuster, you'll also need the parking brake handle from an earlier car. A search might turn up more on that issue.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
deracer
Apr 11, 2016 12:04 AM
Eric-86sc
Apr 3, 2016 03:52 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
