Brake troubles conversion
Old Apr 24, 2011 | 11:25 PM
86z28Dave's Avatar
Hi i got an 86 trans am parts car with 5 speed and posi disc rear end. Completed the 5 speed but found problems with the rear end. The mounting bolts are the same for the rear end but all brake components were quite destroyed. i cannot mount my drums on the posi rear end the axles have 4 bolts holding the axle in and pressed on seals n bearings. All of the kits i have seen are with only 2 bolts holding the backing plate for the discs does anyone know of a different kit available? or can i just drill holes? the guts of the 2 rear end are completely different but the mounts are all the same.
Thanks Dave
Old Apr 25, 2011 | 06:00 AM
CameronLambert's Avatar
Re: Brake troubles conversion
That's because it's a 9 Bolt Rear end. Do a search and you will find tons of info on it the majority where 7.5"/ 10 bolts but there are alot of cars with 9 bolts on them.
Old Apr 25, 2011 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Verify whether you have a 9- or 10-bolt. All disc rear ends that I'm familiar with have four bolts securing the backing plate to the axle end (drums have two). Attempting to swap drums to a disc rear would require some work as the axle ends are different. That process can be seen in the following link toward the end:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
