C5 Brake Upgrade
Old Jan 16, 2011 | 05:47 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
C5 Brake Upgrade
I know this topic has been discussed plenty of times but I found a website that has posted the PN of whats needed. My only question is that this topic doesn't mention the installation so i was curious if you still need to custom modify anything?
http://www.gmhightechperformance.com...ade/index.html
Timinsk
Old Jan 16, 2011 | 06:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: C5 Brake Upgrade
its like any other brake upgrade for a 3rd gen, you need to modify the spindle, and use the custom hubs and brackets to mount the rotor and caliper
Old Jan 16, 2011 | 06:20 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
http://www.superchevy.com/technical/...kes/index.html
Just flew by this article and nothing said about modifying the spindle?... am i missing something? or are the upgrades besides these using different parts needing to modify?..
Old Jan 16, 2011 | 06:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
that article is not about a c5t upgrade, they are using stock type rotors and those crappy overprices tiny 2 piston ssbc calipers that bolt on in place of the factory iron caliper. A total waste of money, but no spindle mod needed.
Old Jan 16, 2011 | 10:28 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
oops; i overlooked that; thought it was the c5 swap.. hmm so what is needed for the c5 swap for it to work? just spindle modification? and if so what do i do to the spindle?
Old Jan 17, 2011 | 05:27 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I have that issue! Thats what I based mine from. You have to cut the ears from the spindle and redrill the dust shield bolt holes out to a larger size for the adapter brackets. OR you can go to flynbye.com and buy the spindle and brackets already done from ed miller(eb miller on here) for a good price. Great brakes for our cars!!
Old Jan 17, 2011 | 06:42 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Wow thats awesome! he has so many to chose from.. I don't know what I want; haha!
Old Jan 17, 2011 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check post #7 of the link to follow:
https://www.thirdgen.org/forums/brak...-spindles.html
JamesC
Old Jan 17, 2011 | 10:51 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Here is another option, my friends, since Eb is so busy now a days: www.bigbrakeupgrade.com This is where I sent my spindles to get moded for my C5/06'GTO front brake upgrade. The work done is flawless and at a good price. He replies quickly, too.
Old Jan 17, 2011 | 03:39 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
beautiful! thank you both!
Old Apr 20, 2011 | 08:38 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Are the modifications to the spindle to convert to LS1 brakes the same mods to convert to C5 brakes? looks like Ed's brackets for the LS1 calipers and C5 calipers are different? If it has anything to do with it...
Old Apr 20, 2011 | 08:51 AM
JamesC's Avatar
I assume the spindle modification is the same (can't imagine how the modification would be different) for all the above and only the brackets are different.
JamesC
Old Apr 20, 2011 | 08:52 AM
JamesC
Thanks James
Old Apr 20, 2011 | 12:08 PM
CameronLambert's Avatar
Thought the difference between moding for LS1 spindles and C5's you had to remove the steering stop for LS1 but leave it in for the C5's
Old Apr 20, 2011 | 12:25 PM
JamesC's Avatar
There is no stop on the spindle, but there is on the a-arm. A-arms for 15- and 16-inch wheels have different stops, BTW.
JamesC
Old Apr 20, 2011 | 01:13 PM
Roc Me 2's Avatar
Car: 1989 Iroc
Engine: In the works!!!
Axle/Gears: 9-bolt, 3.73 gears
Does anyone have a diagram of how the spindle needs modified? I thought I had one and now I cant find it.
Old Apr 20, 2011 | 01:15 PM
Theres a thread kicking around with it, i believe its by Fueled Soul, not positive. I'd say search for it but i tried and couldnt find it myself
Old Apr 20, 2011 | 02:00 PM
JamesC's Avatar
Look at the link I posted above, post #7. More pics in the following link:
http://classic-web.archive.org/web/2....html#1LEfront
JamesC
Old Apr 20, 2011 | 03:25 PM
Roc Me 2's Avatar
Car: 1989 Iroc
JamesC
Old Apr 26, 2011 | 10:10 AM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
When I did my first C5 setup I went here.
www.LukeSkaff.com
Shows where and how to do mods. You can do them on the car. I start with a drill 1/2 the finish size, them finish with correct size.
Old Apr 26, 2011 | 02:37 PM
www.LukeSkaff.com
that is an excellent site to use but what i dont get is why are the brackets different for LS1 and C5 caliper mounts to spindle on that site? look at the PDF for the LS1 bracket then look at the PDF for the C5, shouldnt they be the same? i also noticed on flynbye the brackets are the same unless hes using a stock picture for the C5 which happens to be the LS1 bracket.....
Old Apr 26, 2011 | 04:00 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
NO LS1 rotors are 1 inch smaller then C5. So the bracket locates the caliper abutment bracket in right position for setup you are using.
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
