Brake Guidance for a 1990 GTA
Old Apr 30, 2011 | 04:16 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
I need help selecting the appropriate front disc rotors and pads for my 1990 GTA. Mine has front discs and rear drums, all stock. My rotors are worn and need to be replaced.
I read a few posts here and I've decided to go with slotted/grooved rotors. Also, I'd like to go with Hawks brand pads.
Can anyone tell me if these rotors (http://www.hawksthirdgenparts.com/82...frontrorl.aspx) will fit my car? I have the stock 16" GTA wheels. Item number is 126.62013S (Old #8213-PS)
Also, can I use these Hawks HPS pads (http://www.hawksthirdgenparts.com/ha...ofirebird.aspx) with my stock calipers? Item number HB119F-594. These won't generate a ton of noise, will they?
I am also considering this combo (http://www.hawksthirdgenparts.com/ca...wheeldisc.aspx), but I'm not sure if the pads are as good as the HPS. Any recommendations?
Frozer!!!
Jan 19, 2024 04:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
gta90
Sep 15, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
