Quick Question?
Old May 12, 2011 | 03:20 PM
dmyruski's Avatar
Car: 92 Camaro Z28
Quick Question?
I have a 92, Z28 and i have a friend who has a junk 94 z28. Question is will the rear disk brakes off his work on my axle? and if so is it just "plug and play" so to speak or is there modification needed?
Old May 12, 2011 | 03:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Quick Question?
If you have discs on your 92, you have the same brakes as the 94. If you have drums, the brakes from the 94 will fit with axle flange modification or kit from Ed Miller. There's also the combination valve and parking brakes cables to consider. The following will answer many of your questions:
https://www.thirdgen.org/forums/tran...-10-bolts.html
You might simply consider swapping the 94 rear end into your car.
JamesC
Old May 12, 2011 | 05:49 PM
dmyruski's Avatar
Car: 92 Camaro Z28
Re: Quick Question?
Thats all I needed to know! Thanks!
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
