82 disc reared with a 89 proportioning valve?
Old May 15, 2011 | 01:51 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
my reared is and 82 or somewhere around there and it has disc brakes on it. my car is a 90 and i was going to put and 89 proportioning valve in there. will that work for a four wheel disc brake setup?
Old May 15, 2011 | 02:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 82 disc reared with a 89 proportioning valve?
Let me try again. There are two 1LE combination valves, a first and second design (early 89 and late 89-92). Because of the difference in tube nut threads in the those two designs, one will fit your 90 and the other won't. That said, remember that the 1LE valve is specifically designed for 89-92 cars with the so-called 1LE rear disc brakes (alum PBR calipers and 11.7" rotors) and not the 82-88 standard disc brakes (iron Delco-Moraine calipers and 10.5" rotors).
You might do a search on adjustable proportioning valves.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
