Master to booster leak??
Car: 83 z28
Transmission: 5 speed
Looks like there is brake fuild leaking from where the master bolts to the booster is there a gasket in there? You can see were it's wet running down the front of the booster.
Car: check
Engine: check
Transmission: check
Re: Master to booster leak??
RBob.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im sure there is a o-ring inside the master thats causing this, but IDK if its a serviceable part. New masters are cheap, and simpler than tinkering with the 20+ year old one
