SLP Line Lock install help
Old Jun 2, 2011 | 06:57 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I am trying to install SLP's line lock kit and am having some problems. See photos i attached. It is taken out from the housing in the photos.
I have a double flared brake line coming into and out of the line lock. I install the brake fitting as tight as possible but i can still slide the brake line in and out maybe 1/8". This doesnt seam right.
Am i using the wrong fitting? Inside the line lock there isnt an inverted flare or anything to receive and seal to the double flare of the brake line, instead its just flat and the threads for the fitting dont go all the way in, maybe about 2/3 or so.
I appreciate the help.
Attached Thumbnails SLP Line Lock install help-dscn0063.jpg   SLP Line Lock install help-dscn0064.jpg
Old Jun 2, 2011 | 07:22 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: SLP Line Lock install help
there is a adapter that you dont have in the bottom, b4 you put the line and fitting on..
Old Jun 2, 2011 | 07:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, i believe the line lock only has a 1/8"npt thread in it, its not a flare connection. there is a brass adapter you screw in first that accepts the flare fitting. should have been in the slp kit.
remake that flare, it looks really crooked. make sure the line is cut square, and you debur the inside and outside of it before you flare it. lube it with a little brake fluid works well too.
Old Jun 4, 2011 | 12:01 PM
Car: 1992 z28
Thanks guys. went to a local performance shop and got what i needed. the kit didnt come with any of the fittings which is disappointing. The instructions dont even mention it...
oh well, anyways i have it now.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
fonzie85
39
Mar 16, 2016 07:07 AM
I'llrocya
Feb 2, 2016 11:43 PM
