brake question
Old Jun 5, 2011 | 01:30 AM
88rsbenjy's Avatar
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
brake question
i have a 88 rs camaro. i got my brakes done last month and was hearing a rattling b4 that on my tire. the guy at the shop said i need a new bushing on the caliper but i cannot find anything about brake caliper bushings on autozone.com. i dont know maybe i just missed it or maybe it goes by another name. any help to push me in the right direction is helpful.
damn i wish i didnt forget my haynes manual at my buddy's house
Old Jun 5, 2011 | 02:54 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: brake question
What the mechanic meant was your caliper slide bushings. You should be able to purchase a caliper hardware kit at any parts store. It will come with bushings and o-rings. Be sure to install the new o-rings to eliminate the rattling.
Old Jun 5, 2011 | 07:47 AM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
Re: brake question
is this what your talking about?
http://www.autozone.com/autozone/par...28051_0_0_5917
or this one
http://www.autozone.com/autozone/par...4371_0_0_46599
Old Jun 8, 2011 | 10:16 AM
cimism610's Avatar
Re: brake question
Hey whats up , the part that you need is a front disk brake hardware kit . It includes the metal bushings and the rubber that goes between the bushing and the actual caliper. This makes it fit snug. I am in the process of doing this on my 88 trans am. I ran across your thread as I was trying to find directions on how to install them correctly. I will give you the part number in a minute.
Old Jun 8, 2011 | 10:20 AM
cimism610's Avatar
Re: brake question
Yo I didnt see that someone allready responded to your question. As for the correct hardware kit. it is the second one with the 4 barrels and o rings. Good luck .
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
