help with e brake cables
Old Jun 24, 2011 | 11:14 AM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
i am swaping out the old drum brake rear end out of my 92 rs and putiing in a a 88 iroc 350 rear end with disc i got brake cables from the store and the pn# is wagner F130684 and they dont look like they work for either rear end ill try and upload some pics later what cables do i need please help
Old Jun 24, 2011 | 11:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: help with e brake cables
do you have the aluminum or iron calipers?
Old Jun 24, 2011 | 10:23 PM
Transmission: auto
iron single piston
Old Jun 25, 2011 | 05:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This backward swap seems problematic: First, the 88 would have been equipped with a tunnel-mounted parking brake adjuster; your 92 doesn't that that piece. Some members have swapped in the parking brake handle, etc., effectively making it an 82-88 system. Then, of course, the tube nut design changed in late 89, so the earlier disc combination valve won't fit. In the long run you might be well advised to use flynbye's drum-to-disc kit and swap on the much more desirable PBR's.
JamesC
Old Jun 26, 2011 | 08:58 AM
Transmission: auto
so i got the 88 brake cables now with the brake themeless is there a spring that suppose to be there with the e brake running through it cause i have two springs and im almost positive they were attached with the embark in some way and that the pic is th adjusting plate for the brake btw that in my 92
Attached Thumbnails help with e brake cables-0625011112.jpg   help with e brake cables-0625011112a.jpg   help with e brake cables-0625011109.jpg
Old Jun 27, 2011 | 05:57 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
^ I need a set of those springs and cannot seem to find them anywhere do you think you could measure them for me?
Old Jul 29, 2011 | 10:30 AM
Rumble Bucket's Avatar
Car: 91 Firebird Formula
Transmission: 5 speed
just found your post . wondering if you got it finished because im doing the same swap with my 91 formula . Did you get the e brake cables to work . thanks
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
