ANYONE run No Rear Brakes?!?
The car is setup for drag, not a street car, 92 z28 1LE, cant fab any rear brakes to fit currently with 15" wheels, might have to go aftermarket, but thats $$$ wondering if anyones brave and drag racing with no rears and what they think
Car: 87' IROC
Re: ANYONE run No Rear Brakes?!?
I doubt your local tech inspection will let you on the track with no rear brakes. You may want to check out the NHRA rule book.
Functionally you will probably be fine as the rears only do about 30% of the stopping any way. How fast are you planning to go?
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
I sent you a reply in another thread. You rear wheels I believe are the problem. They have alot of clearance issues, search them on ls1tech.com
You setup a 1LE car for drag only. Talk about ironic.
hectre13
Dec 11, 2023 08:14 AM
