NEED HELP!!! 1LE brakes and 15" rim Problems!!
Old Jul 9, 2011 | 01:06 PM
Cthornsmax92's Avatar
I own a 92 z28 that was optioned with 1LE package, I just installed a drag bar from bmr panhard bar from bmr lca's from bmr, 1 1/2" spring from bmr,
i went to fit my NEW Greg Weld 15x8 4.5"bs wheels with 275/60-15's, when i tried bolting the wheels up, once they wldnt center nicely i tightened the wheel to see if it would rub when lowered, but they wouldn't turn at all , it was rubbing on my caliper.
i than bravely grinded down the cooling fins on my caliper STILLL it doesn't fit but they now Center on the hub which they were not doing before grinding, but still do not clearance evidently the wheel will turn, with force , but not much.
The caliper is smooth on the half of the caliper inside the wheel lip. Hoping someone can help! have a 92 rs anniversary car for parts which has drum rears, but would like to keep my 1LE parts. hope someone can tell me something im not thinking of. Please help !
Old Jul 9, 2011 | 08:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: NEED HELP!!! 1LE brakes and 15" rim Problems!!
will a small 1/4" slip on spacer fix this?
Old Jul 11, 2011 | 07:02 AM
ihatemustangs's Avatar
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
I have those brakes on my 86, and had to grind them to run 15x8 prostars. I also ran that thin factory spacer and they cleared.
Old Jul 13, 2011 | 09:12 AM
you know idk i wouldn't think so because the caliper sits so far inside the drop center of the wheel, its agood 2" inside the drop, but its possible.
Old Jul 13, 2011 | 09:13 AM
hmmmm i haven't Ground the wheel down.. did indeed gringo the **** out of the caliper though with no luck, ordered a rotor and caliper from a 84z only 10.5 " hopefully i can configure something to work so i have Rear brakes! lol ...
Old Jul 13, 2011 | 03:58 PM
I know for fact that the 4th gens need caliper grinding for 15" wheels, but the rear greg welds didn't fit them even with grinding. They were supposed to release a rear wheel that would clear the caliper, but I don't personally know if they did.
Old Jul 13, 2011 | 07:02 PM
well i do know now that the greg welds Wont fit cars with 1LE rears, had to put my old draglites on ;( .. racelites by Greg Weld now for sale in Classifieds, good for drum or pre pbr caliper cars
Old Jul 13, 2011 | 07:18 PM
A few companies make there wheels now able to clear the newer big brakes. If you search drag wheels on LS1tech.com, I believe someone listed what popular wheels will fit with how much work/ no work. Good starting point to follow as to what the big brake third gens need. Good luck!
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
